G
Guest
Guest
Make sure the spacers under the flywheel shroud are still there also. They can vibrate out and then the engine hangs off the gear plate.
Agreed. Pulling the engine is the easiest way to get to the clutch.cherryride said:you can just pull the motor if the screws you stripped on the underside of the gear plate.
