Hello,
I recently got a new motor GP290 for my Redcat Rampage TT. Started up and idle fine, fresh fuel mixture and all. After break-in, I took it easy around the track but never quite got it to run right. It would just bog down and die and hard to restart. After about 3 tanks, it just would not start any more. I went through all the trouble shooting until finally decided to take the engine apart. Everything else looks fine except I found the connecting rod - section that connects to the crank shaft was done. It was loose up/down and side/side. I double check my fuel mixture and it was 25:1 as recommended. Never seen this happened so soon before. Any idea?
Kenzx
Kenzx
