I've used all the GRP range on my 2wd car for racing in the national series - on Astro turf tracks. For all round performance, the new style "Cross" in the A compound are best but you need to trim 5mm off all the nobbles from new or the just fold over when you drive into the corners. The cubit will give you a fast time if you stay on the racing line but the wear rate is very poor, you'd not do a full 1/2 final on a set, the bulldogs are similar characteristics as the cubit but they last longer - These were used by many at the 2010 european championships as the surface at the track in Austria was hard pack dirt, almost clay. The "Grip" work ok on astro and should be ok on grass.
Hope this helps.
