hard bashing! Wheelies'?
jtakeman
Junior Member
:D OK.
My truck runs OK totally stock, But I am heading down the path of major DESTRUCTION! After all Tom meants is my driver!
I want to put the biggest mill I can find in it. 30.5cc looks to be the biggest out there. What drive upgrades will it require????
TIA
jay
i have a 30.5 ive only changed one dogbone because the pin fell out and a diff mount because i had a bad bearing. just put in and fix it as it breaks. the biggest thing that id say to look out for is fast eddy bearing kit the stock bearings suck also go over every screw and change ur fuel tube
satttheman,
How much better is the bigger mill? I'd like to see wheelies, If possible. I know that it is a heavy truck.
Fg guys are getting a 35cc 4stroke to fit in the MT5. Will it fit this truck with mods???
I'd also like to spool the rear diff for better dounuts, Anybody have info on it?
jay
its alot better especially with the modded hpi ss pipe and the extended mid band i run 30/30 which is 5t better on the pinion and 5t smaller on the spur it gives alot more speed and it still moves on the low as far as wheelies i doubt it maybe when some better pipe come out for the mt5 and/or a nos wet system lol you'd need alot of power because this truck is massive some much power that the truck wouldnt prolly last very long. i don't know about the 4 stroke only 4 stroke i messed with was my crf450r maybe someone else can chime in on that one. i don't know about a spool being made but for now u could jb weld or something to lock it up
Jtakeman the biggest bore I believe will bolt in is the fs 35cc its a true 35cc I believe it has a 40mm bore forum member obeast44 did a thread on the 35cc
