DemonRC1
Hey what servo horns are you guys running with sucess? I DNF'ed my qualifier tonight cause my plastic one stripped and I had at least 1/2 lap on the Baja behind me. Kinda a bummer really.
I'm using the HPI servo as well. I bought mine brand new off of ebay for 45 bucks.Gas Jocky said:I've run the swb horns and they bend easy, I've since changed one of my trucks to the HPI sfl-10 mg2 servo and it seems bullet proof, a little pricey but no issues as of yet
I picked that 1 up at the LHS today.csp1971 said:Check this out cat:
http://www.hpibajatutorials.com/showthread.php?t=1274
Yeah, if you need a strong servo horn, replace the servo. If you need a new tire, replace the entire rc.AlvaSpeed said:get a Rhino servo.
It is Heavy duty.
The horn is massive.
catchaser said:Hitec 5745. I ended up buying an aluminum one at the LHS with a clamp but the material isn't that thick. The horn won't strip, however, I'm worried about twisting the arm. I think I'm going to move off to another servo with a bigger output shaft.
