Head kit
Rampage mt
Nova Scotia canada
Hey got a question yet again haha.putting another ddm order in shortly and in that I want to get a head kit http://www.davesmotors.com/cc253 that's the one I'm thinking.so do I need the crank and everything or just the head piston etc.will that piston work with a stock crank? Also is there anything else I should have if I get this kit? Thanks
You do not need the crank, but you really don't want to run the reinforced gasket because it is too thick your squish specs will be way off! When I installed mine I used the zen 2 bolt gasket which is what Doug the maufacturer of the head suggests it measured .015 and I had a squish that was not even close to specs so now I run a .005 copper gasket and works great, you are mounting this on a 30.5 motor correct?
The reinforced gasket is like the same thickness of the stock one but I haven't checked the squish cause I was told I didn't need to
Ok,welp I think I'm gonna get headkit with this orderig I'm gearin up to put in and ill get a set of reinforced gaskets and the copper one too just incase I guess.
Did u notice a big power differance?
Rampage mt said:
Ok,welp I think I'm gonna get headkit with this orderig I'm gearin up to put in and ill get a set of reinforced gaskets and the copper one too just incase I guess.Did u notice a big power differance?
Makes a huge difference in power
Yes
That top end is a beast I put that same one on my dune runner with a belt drive and rear Dom and I am happy ! :D :D
