Helo with keeping oil in diff
maddmike
Every time I fill my diffs with oil it leaks out. What am I missing here. I use 7k rear and 5k front . The o rings on diff cup sides are there. And so are other 4 o rings on the bevel gears.
Where are they leaking? If all of the O-rings are there, maybe you're not tightening the ring gear screws enough. Could be the set screw on the side of the housing, as well.
Set screw is in case and any tighter on the ring gear it strip. O ring issue maybe
