Daddy~O~
New Member
My Baja 5b won't start. I have changed out the following with new:
Gas Tank
Coil
Carb
Piston Ring
Spark Plug
The only thing I can say is that during all the changing of parts the only time I got it running was after I changed the piston ring, but it ran horrible, before I could do any fine tuning it died and now it won't start again. I have checked the case for leaks or cracks and everything looks fine. I have alittle over 90lbs of compression. Everything is all stock parts. I haven't upgraded since I can't seem to get the stock parts to run. I also have a stock Baja 5b and I have never had any problems with it so I don't understand how the 2 of them can be so different. Anyone have any suggestion on what I should try next?
Gas Tank
Coil
Carb
Piston Ring
Spark Plug
