Help can’t connect my cpi exhaust to my blackout
johnboy
Wakefield
Try to connect my cpi exhaust to my maverick blackout what a nightmare the manifold side is a lot smaller then the exhaust can’t connect them both together with the rubber exhaust hose as one part is bigger then the other any advice would be most appreciated hope you get what I mean or any ideas
johnboy
Wakefield
The rubber pipe has split that connects them together but the exhaust part is thicker then the manifold side not sure how to do it
johnboy
Wakefield
Guys is your manifold the same size as the other part of your cpi exhaust the end where you connect them both
