rob64n said:i normally just use a socket that is the same size as the outer bearing race and a rubber mallet. once you pull the snap rings the drive out easy.
Heat your oven to 300 degrees (f) put in the case for 15 minutes. Remove. Pop bearings out.island said:
How about the rubber seal how do i remove that? Didn't know they had snap ringswill try that when i get home
Thanks rob64
If I stuck my engine in the oven my family would be sitting at the dining room table, knives and forks in hand, asking why the potroast smells like oil.csp1971 said:Heat your oven to 300 degrees (f) put in the case for 15 minutes. Remove. Pop bearings out.
It works great man! Clean it up first!DemonRC said:If I stuck my engine in the oven my family would be sitting at the dining room table, knives and forks in hand, asking why the potroast smells like oil.
lOlDemonRC said:If I stuck my engine in the oven my family would be sitting at the dining room table, knives and forks in hand, asking why the potroast smells like oil.
