hey guys, my name is allan from chicago. i have a Rampage MT. I have already replaced the upper/lower arm to aluminum (front and back). Installed a new rollcage and switch out the pull start to electric. Gone through the check list before getting it started and its been a week and she still wont purr!
So far this is what i've done:
- correct gas/oil mixture
- set the High to 1 1/2 and Low to 1 1/4 turns (counter clockwise) after turning it all the way till it lightly touches the bottom
- purged the bulb 3 times after it filled up and closed choke the tried pulling for 5 times (before i swapped out for electric start)_
- opened choke after and pulled 5 more times
- checked the plugs for spark and they are good. at first i thought spark was week but after i tried the plugs from my weed wacker, i get the same spark. so thats ok.
- swapped the electric start and still wont fire up.
- drilled out gas cap (5 holes) to a bigger size but i'll be venting the tank properly as soon as it starts.
My level of frustration is now on high!!! so any help/tips will be greatly appreciated. thanks!
Allan
Allan
