Help needed with Shengqi Hummer
Alertdan122
New Member
UK
Hi, I need help solving an issue I am having with my 1/5 scale shengqi hummer. The problem is to do with over fuelling. When I go to start the car from cold, if it doesn't start on the first few pulls the engine will flood. The only way it then resolve this is to undo the carb. I can then get the car to start, and it revs high and clears the bore of fuel. Then when I put the carb back on, if I make sure I start the car in one or two pulls, it will start. If it doesn't start, the engines then floods again and it will not start, unless I remove the carb. And repeat the same process. If I can get it started, I have to keep the revs high, otherwise it will over fuel and stall itself and the require the carb to be taken off again. Does anyone know how to resolve this? Any help is really appreciated.
King Regards
Dan
