Help please
Hello, i'm new to this forum. But I love baja's. I saw this rocket kit on ebay, is it worth it? Here is the link: http://www.ebay.com/itm/Rocket-Kit-...pt=Radio_Control_Vehicles&hash=item231aa7f031
Sorry if i ask anything stupid, im just a newby here
To be honest, I'm not sure that I see the point!
The kit may be one thing, but after spending so much time setting up and installing, how many rockets are included?
How easy is it to get a replacement?
If it's just one rocket, then it's done, ....... $190? Not really.
If you really fancy the idea and it comes with several rockets, and more are easy to locate .... that's a different matter.
Al.
Oh ok, thanks. I messaged him and he said it comes with a couple rockets. He said you can get the rockets from any hobby shop, you can get them online, and also he sells the rockets too.
Sounds good.
If you like the idea, it sounds like a plan!!
I would consider the safety / storage implications as well.
Do you remove the rocket each time, if not used?
Is it 'perfectly safe' if the crocodile clips are removed ... ?
Al.
On the safety it would be no different then flying model rockets the engine can only be used once so it the engine has been burned then nothing else can happen. Why would you need to remove the clips if there is no power on the channel the clips is connected to or if the receiver is turned off there will be no power so nothing unsafe to occur. Model rocket engines are very readily available all hobby shops sells them many online places and more so getting the engines will not be a problem at all if so desired.
