I have a DBXL-E 2.0...I need some advice
Issue:
I cannot get full or acceptable L/R turns.
I use a DX5C. I am not new to setting a servo, but this 1/5 is new to me. I have played with:
Issue:
- I placed the servo as center as I could get for the wheels
- I have played with the "sub trim"
- I have played with the "travel"
- Setting the sub trim to 12R (travel at 100/100) will give me somewhat even turns, but they very wide
- If I do not use the sub trim and just play with the "travel," I get a tight turn in one direction but wide in the other
- Do I need a better servo. I have - Power Hobbies Powerhobby 701MG 1/5 70kg Waterproof High Speed Torque Metal Gear 5th Scale
- I never used a servo with two arms. The holes on the servo horn were the only ones I could reach to the Ackerman it was tight getting seated. There are 3 positions
- Do I need a separate servo for left/right for better turning
