Help verify my thought process please
freekshow
on my third tank with my XB. Seems to be breaking in. When I am at 1/2 to 3/4 throttle it accelerates well and picks up speed but when I push it to full throttle it just stays the same or slows down a bit. Too rich ? It seems to run better and peppier at 1/2 and 3/4 throttle than at full....thanks for any input...
P.s. Unit does not seem to smoke much out of the exhaust now like it used too but am running same 20:1 Mixture
Thanks
freekshow said:
on my third tank with my XB. Seems to be breaking in. When I am at 1/2 to 3/4 throttle it accelerates well and picks up speed but when I push it to full throttle it just stays the same or slows down a bit. Too rich ? It seems to run better and peppier at 1/2 and 3/4 throttle than at full....thanks for any input...P.s. Unit does not seem to smoke much out of the exhaust now like it used too but am running same 20:1 Mixture
Thanks
Sounds a bit rich
How far out is the high needle (should be 1.5 turns)
Also a bit much oil in the mix (should be 25:1)
humidity can steal top end and can force a rich setting. it may snap up quick at lean setting and seem decent but too long at that setting is not so good . if its cool and dry(or at elevation) try to favor a fraction fatter setting.
servo action and carb throttle arm need to be tediously in coincidence...servo action may push into stop at 3/4?? check EPA and throw action
definitely 25:1 if already got some time on it
stock pipe/carb also has limits as well
