Here's my video for new bearing install
Awesome video. Look out, Team Fast Eddie, rob64n is in the house.
Very thorough. You made it look easy. Anyone should be able to follow that for a full dif rebuild. A+
Thanks guys, I had a little over 42 minutes of video clips. So tryin to shorten that up took alot of patience, but didn't turn out too bad. I wanted a little more effects in there but windows 7 movie maker wouldn't let me do some things. I'll have more to come as I get more bearings. I think when I get to the wheel bearings I'm going to have them put a dry lube instead of grease in them....
Vision said:
Yikes those are $16 per bearing. How long do the stock bearings typically last ?
stock ones don't do too bad, the price you're looking at, make sure it's not the C3. these are around $11 I believe, but I'll have to check to see if they have quantity breaks.
main reason I thought to use these was the speed and of Demon RC's two speed and also the XB-e for heat reasons....
I run my xbe only on-road so I'm hoping the stock bearings will hold up. We'll see I guess
I've heard people say that the 1/8 scale brushless cars are having bearing failure due to heat from the high rpm, so these bearings will help I'm sure. Since 1/5 scales are three times the weight and much more rotating mass.
