Sold / Found Hilantronics HLT5000WP 50KG Digital Servo
Status
Not open for further replies.
Zephyr
2 Stroke’s & Titties
Build Thread Contributor
Essex
£125 posted in the
Excellent quality servo with some great features (overload protection, auto cut off etc)
Was bought new and fitted to the car, it has not been run yet as you can see from the condition. Selling as I am upgrading to the 70KG model.
Video of the servo in action can be found here;
Designed and Manufactured in Australia.
Unbreakable fully billet casing, waterproof *, 15T gear teeth, heavy duty metal gears, quality core metal motor, smart digital signal controller with Led status signals for diagnostic, quick disconnect servo lead, current limiter and over temperature shut down if servo ever got stuck to prevent the controller board from being burnt out, automatic shutdown if no RX signals present.
Servo require 3 to 5Vdc square wave pulse. Pulse duration is from 0.9mS to 2.1mS with 1.5mS as center. Servos can be operated within a 6V-8.4V. range. The Black wire is 'ground', the Red wire ( center ) is 'power' and the third wire (white) is 'signal'.
LED Signal Status:
- Green Flashing: No Radio Signal / Inactive
- Red Flashing: No Radio Signal / Low Battery / Inactive
- Green ON: Active
- Red ON: Low Battery voltage (Below 6 Vdc)
- Red/Green ON: Safe Mode (Current Limited)
* Servo is splash- and water-proof, but submerging is not recommended
  • Like
Reactions: JT3
Status
