Hip Baja. 5b. Clutch problem
Jones icc
New Member
I just bought a 5b. And I'm havin a lil trouble... The buggy runs and drives awesome but at idol it keeps wanting to move forward... It was fine for about 20 min or run time then started this problem any suggestions of what could b wrong thanks
Hi Jones.
Welcome to LSF.
In the User CP section you can enter your location. Please do this to help people to help you - might be somebody 'next door' who can pop down and help.
Sounds like clutch is dragging / idle speed is high.
If the clutch spring is weak, then the clutch will open, grabbing the bell - edging forwards.
If the idle speed is high - same thing - this is a centrifugally operated clutch remember.
If there's an obvious difference between COLD (just started) and HOT idle speeds, I'd look for leaks. Air leaks will lean the mixture, which will ..... increase the idle speed.
