Hitec 5755 mounting problem
hotrod45
sarasota, fl. previous st p/mpls
i just received a new hitec 5755 servo, following the advice of several form contributors, indicating it is a good steering servo. so, the problem i just encountered id that the mounting flange is 1/4" narrower then the pre drilled holes. i am installing this servo in a hpi radio box. you guys who have done the replacement with large scale servos tell me what the trick is here. thanks for your help.
get the one side mounted and flex the mount a lil bit, Thats how I did mine and it has worked perfect for me.
servo
chad, before i tried your method, i went to my box of left over hpi parts and found an extender which screw on the bottom of the mounting bracket and slides toward center so you can get the servo mount holes to line up! worked great!
