HiTec 5755 steering servo for MT
MTMIKE
New Haven, In
Since my wiring burnt up and I sent everythin back to Redcat looking at upgrades. Keep seeing HiTec 5755 for steering servo and HiTec 645 for the throttle. What type of mod's will need to be done to make them fit? Is there a link out there somewhere to view someone installing these or some really good pictures?
+1 on the 645 thats what I am running. I sent mine back to Redcat when they burned up. outstanding support but everything they sent me burned up as well. Stopped with the set of 805MGs I put in my MT I used the futaba mount on the one side and the radio box mod i did to get the other in ... well that was not too pretty but it worked. I am not 100% sure but I believe the 5755 are smaller and easier to fit than the 805s.
I have the 5745's, but the 5755's are the same size and they are an easy install. When you pull out the stock servo you'll see four mounting posts, just lop off the two on the top, mount the 5755 using the bottom posts and drill new holes for the top mounts. Simple as that.
