ho no bro!!my losi MTXL29
Thread starter #1
evssv
Likes
1,499
Bristol uk
so been watching this for the last wk or so. https://www.ebay.co.uk/itm/losi-mtxl-1-5-petrol-rc-very-large-/173346878447?_trksid=p2047675.l2557&ssPageName=STRK:MEBIDX:IT&nma=true&si=7a%2FzszRxFKLJue9wxbLZmzuRKFQ%3D&orig_cvip=true&rt=nc
..and it was on £ with only 30 mins left....I thought no way am I gonna let it go for that..o_O...I`m gonna stick a bid on..:p..so stuck on £ for a laugh...thinkg it`ll go way more then that......they normally make £+ atleast......:cautious:.......so it went up to £ ...20 secs left......ok......sum one else pls bid.....15 secs.....£....then on the last few secs it went ...END!!....ho shit I jus won it....:eek::eek::eek::eek:........the dudes missis was on his case to get it out the house...so he offered to drive a round trip of 360 miles...from chesterfield to Bristol.......for £ extra....so £ for my new mtxl!:D:D:D!
20180612_180257
by evssv, on Flickr
20180612_180323
by evssv, on Flickr
20180612_180317
by evssv, on Flickr
20180612_180312
by evssv, on Flickr
needs a good strip and chk over....a decent pipe.....but may see if my 5ive`s samba might fit on.....
James H.
Likes
11
Southern Utah
..and it was on £460 with only 30 mins left....I thought no way am I gonna let it go for that..o_O...I`m gonna stick a bid on..:p..so stuck on £525 for a laugh...thinkg it`ll go way more then that......they normally make £700+ atleast......:cautious:.......so it went up to £480 ...20 secs left......ok......sum one else pls bid.....15 secs.....£490....then on the last few secs it went 505....END!!....ho shit I jus won it....:eek::eek::eek::eek:........the dudes missis was on his case to get it out the house...so he offered to drive a round trip of 360 miles...from chesterfield to Bristol.......for £35 extra....so £540 for my new mtxl!:D:D:D!
20180612_180257
by evssv, on Flickr
20180612_180323
by evssv, on Flickr
20180612_180317
by evssv, on Flickr
20180612_180312
by evssv, on Flickr
Why is this under DBXL?? LMAO
Thrasher
Likes
169
James H. Because they insist it is a DBXL because it shares a few parts with it lol. We are actually a few owners of MTXL's on the forum, me included. OP enjoy. Its hands down the greatest basher ever. It is purpose build for bashing and it will take a beating and then some without giving in. Get a metal servo saver, you will regret not doing so.
This one is very popular but Losi have made their own where you only get the actual servo saver and put into the steering mech.
https://www.ebay.co.uk/p/Hot-Racing...itm=392040929193&_trksid=p2047675.c100623.m-1
Thread starter #14
evssv
Likes
1,499
Bristol uk
Thread starter #15
evssv
Likes
1,499
Bristol uk
not sure werethe blue link was from but it was major loose as there loooekdto b a insert missing....so I made made sum
20180614_204113
by evssv, on Flickr
20180614_203209
by evssv, on Flickr
did the washer mod so no popped off rod ends...
20180614_221308
by evssv, on Flickr
judging by the look of the pins it had much use....
20180614_230023
by evssv, on Flickr
so 100k in center diff...all looks good in there...actually had diff oil in there still
20180614_233042
by evssv, on Flickr
fr diff seemed very loose aswell...
front diff looks good aswell...new bearings all round..60k in the front
20180616_140548
by evssv, on Flickr
sorted once shimmed..
Thread starter #16
evssv
Likes
1,499
Bristol uk
Thread starter #17
evssv
Likes
1,499
Bristol uk
Thrasher
Likes
169
Me an others run really heavy diff oil. 500k in the middle and 300k in both ends or 300k back 100k front, whatever takes you fancy. A heavy run will make the diff cups so hot you will consider getting alloy ones. I have yet to see one of the original ones melt tho. Try it out, you will be surprised at the difference it makes. You "new" truck has seen a lot of use. And you should probably take a look at how well the steering servos are alligned.
Thread starter #19
evssv
Likes
1,499
Bristol uk
so....jus waiting on me xt30 connectors for the kill switch......need sum shox socks...fit me ally engine mount..gota ally clutch bell holder on the way plus the centre shaft holder on the way....gonna stroke the engine to 30.5 with the kit I got here....
Thread starter #20
evssv
Likes
1,499
Bristol uk
...well the pins say other wise imo..as I wore the pins on my dbxl with in 10 ltrs of fuel....shocking wear rate....
they look/work fine.....obv not ran it yet....and I`ve gone over every thing all bar the clutch which spins freely but will sort once me ally ones here...I run this diff oil set up in my 5ive...I did order 500k but I`ll see how this works....:)...quite happy only issues was 1x rounded out hex....:)....either way I`m well happy with it...:p
