Holiday
rampage idiot
Indiana Pa.
Today is a special day indeed!!! I just noticed there is an MT section on 7075rc Now!!! This can only mean great things now, I knew if we whined enough it would happen! :D Thanks Doug
That's just for the drive cups. But I could buy one to revers engineer it. What kind of parts would you want. I hear the MT is pretty tough.
I think bearing holders to start. Yours take out all of the slop.
I also think for all models, turnbuckles. To replace steering and upper links. The MT uses upper arms but they are not necessary. I run links for uppers on my 5ive which is much larger than the MT and they are fine. The huge MT wheels shake and wobble like crazy. It is only because of the bearing holders and sloppy rod ends.
RCDAD said:
I think bearing holders to start. Yours take out all of the slop.I also think for all models, turnbuckles. To replace steering and upper links. The MT uses upper arms but they are not necessary. I run links for uppers on my 5ive which is much larger than the MT and they are fine. The huge MT wheels shake and wobble like crazy. It is only because of the bearing holders and sloppy rod ends.
+1 on the links!
