Hostile MX nightmare tires and FG Baja
naftausa
Firenze, Italy
hi..
are the Hostile MX Nightmare compatible with fg baja stock rims? they r sold for HPI baja rims.. :dots:
if they arent,, which rims should i use to mount this awesome tires on my FG baja?
many thanks
No. The HPI uses deferent inner diameter for the inside and outside (the sidewall on the tiers are deferent from the inside and outside). The FG uses same diameter on both sides.
You can use adapters to mount HPI hex on FG to use HPI tier & rimes. Or use FG rimes that can use HPI tiers.
Check this link.
http://www.davesmotors.com/store/rcwheels.html
