how do i fix....
Jay Gomez III
Camas WA
I am having trouble with my OWB on my two speed , they are going out way to fast. I was hoping some one can tell me how to adjust the gear mesh by moving the engine mounts, this is my first Baja 5b large scale rc. and don't know my way around the Baja yet. how many and where are they located at? I guess my OWB is going out is because my gear mesh is to tight?? what is a easy way to do this? I have a ksrc 002 30.5cc two speed king motor. please any help thanks
http://www.ebay.co.uk/itm/Brand-New-Heavy-Duty-Upgraded-NSK-CSK12-One-Way-Bearing-for-King-Motor-2-Speed-/300944491273?pt=Radio_Control_Parts_Accessories&hash=item4611b08309 i brought this one been using it for two years now no problems and that was on the km 30.5cc and now running the zenoah g290. theres no way of adjusting the gear mesh on a baja like there is on a nitro but if you loosen the bolts holding the motor and the gear mount you might get a bit of movement.
I tried that and it did give me some movement, now its moving back and forth just fine, hopefully the owb will last longer now, I am going to have to put Loctite on it just in case it wants to come loose.
thank you
I'm installing a 2 speed and the large gear just dosn't want to go on easly on the main shaft where the 2 pins are... I don't want to beat it on... anyone have this problem?
I had the same problem with my 2 speed, my big gear did not want to slip on I found out it was the one way bearing, the notches in the bearing were not even and it caused it not to go on, I returned the bearing as defective and was shipped a new one. new one fit right on, might want to cheek that?? I also ordered a new owb and had that happen again, so I did not want to wait for another bearing so I filed down the notches
and made it work. and the bearing has lasted since I installed it,
loosen the screw that holds the pinion gear just a little bit, your gear mesh will be looser. it worked for me, be sure to put Loctite on the screw.
