- Reaction score
- 27,691
So I need to cut 1/2 aluminum, 1/4 inch steel, and a steel exhaust, what should I cut this with?
Kk here's some photosIt would be easier if you posted pics of what your trying to cut . But since you're being generic I'd say a sawzall with a hacksaw blade.
If it needs to be presise a dremel with a cutoff wheel or a regular hacksaw.
No but I could rent one. I think I'll rent a jigsaw, a sawzall would be good for the pipe?I'd use a Dremel with a good cutoff wheel for the pipe. Hacksaw for the aluminum. If you have a sawzall you could use it on the steel with a hacksaw blade . Just take your time. Do you have a jigsaw? They sell hacksaw blades for them, you could use that on the aluminum plate and the steel plate.
Maybe rent/get a chop saw? That would be easier for the exhuastYou could the blade may try and wonder on you when you start cutting . You can buy a Jigsaw pretty cheap .
