how is KM-X2 DELUXE? With full alu parts, is it better than Losi 5ive?
Emrah Ozturk
Hello,
Im looking for KM-X2 Deluxe.
Anyone experience with them?
Is it better than Losi 5ive 29cc?
Vehicle configuration
Power
New Rev 30.5cc engine,2-stroke, aircooled
Fatboy Ⅰ /Fatboy Ⅱ (option)
walbro carburetor #997
NGK spark plug specially for model
High performance 8000RMP clutch
L-W-H(mm):817mm*480mm*255mm car size
Net weight:17KG
L-W-H(mm):1050mm*580mm*450mm package size
Gross weight:23kg Volume weight:54.8KG
Frame
5mm chassis with CNC machining for strength and less weight(Billet alum 7075)
Large-bore shocks with 7mm shafts & threaded adjusters
Adjustable bias dual-disk braking system
O P
3、6061-T6 Billet alum Front shock tower X2-002F
4、6061-T6 Billet alum rear shock tower X2-002R
5、6061-T6 Billet alum Front suspension block-left X2-003FF
6、6061-T6 Billet alum front suspension block-right X2-003FR
7、6061-T6 Billet alum rear suspension block-left X2-004RF
8、6061-T6 Billet alum rear suspension block-right X2-004RR
9、6061-T6 Billet alum rear chassis brace L006
10、6061-T6 Billet alum front chassis brace L007
11、6061-T6 Billet alum Differential mount-1 L008
12、6061-T6 Billet alum Differential mount-2 L009
13、6061-T6 Billet alum front chassis spacer L010
14、6061-T6 Billet alum Rear cage mount&fender brace and Hardware L012
16、6061-T6 Billet alum Sway bar set L013
17、6061-T6 Billet alum cluth housing L015
Shaft
Front and rear CVD
3 differentials for front ,rear,middle
Multi-piece beadlock off-road wheels
Electronic equipment
Receiver:6V 4800MAH nicked metal hydride set with short circuit protection inside.
Throttle servo:KM-4500 50kg throttle servo.
Radio:3-channel 2.4GHZ digital radio control high response system.
BONUS
1、L wrench(1.5MM-4MM)*1
2、Sparkplug tool*1
3、tire tool*1
4、multi-function wrench*1
5、ratio tank*1
6、manual*1
7、Recharger*1
8、X2 sticker*1
9、X51023*1 X51043*1 X51044*1 X51009*1 X51049*1 X54006*1 X54002*1 X51018*1 X51017*1 X54004*1 X54005*1 X54008*1 X51016*4 X51030*1 X51042*1 X51058*1 X51059*1
10、Tool bag*1 66013
http://en.kingmotor.cn/hot/show-69.html
I don't have an X2 but from reading this and other forums....It's a clone of the Losi. Some have had a good experience with it, some have not...
I just bought a KM X2 DELUXE Roller and you can not even begin to compare it to a Losi. I have a LOSI 5T that is my gas truck. I bought the KM knowing that from others that have them but i got it for a custom Brushless build. I have a hobby store going out of business and they had a 50% off sale so the KM is now more than 75% LOSI parts. Also bought front , center and rear complete diffs from Dollar hobbies along with a few other
Parts. The aluminium center diff mount on the KM is a joke its so sloppy it would not last 5 mins of run time. And the diffs feel like there is dirt in them.
If I didnt have the 50% off sale for the LOSI parts I would have not bought the KM but like I said I knew going into it that I would have to replace some parts but I'm shocked these these trucks even run. I still saved $400 going this route compared to buying another LOSI and doing the brush less conversion. Plus I enjoy working on them. I bought a Dynamite Fuse 800kv 6 pole motor and a HobbyWing Max5 200amp ESC I'm only going to be running 8s so it should be fine. This is just for bashing when I have to be quiet. I'll be running SMC 4s 8000mah 90c batteries with a RC Madness conversion kit. A friend of mine has a DBXLE and it has the Same motor and batteries and its a animal I know the 5T is heavier but I'll be using a receiver battery for the servos and the mechanical brakes so I'm not worried about the motor
and ESC temps getting too hot. I'll post how it goes soon as I get it all together.
