how to install bevealed gears?
rixxer
Brampton, Ontario
just bought the 4WD kit for my MT first in the installation instruction is putting thespider gears inside the differential housing after few hours im frustrated and unsuccessfull is their a trick on how to install this part? please help guys :-(
yes mate,If its the same as a standard FG diff you have to get them band on or you will never do it .there is a tool for this. It looks like a cross that you slide the gears onto and that gives you the perfect alignment.If you are just one tooth out you will have difficulty getting the diff back together.
J.
I hold the 4 gears in my hand together then slide the dif case on. if you put the pin in but cn't wriggle the outdrive in it's time to try again. I've done it enough times now though. check the alignment before putting the sleeve on just in case. you can also reach the gears to move them if need be.
