How-to Install Your Inclined Shred Stack
Bigger the Better
LSF Plus Member
PLUS member
Minnesota
How many times have you just about thrown your filter across the room because you can’t get that darn filter on the bottom between the fuel tank and the filter system?
Well here is a great little item to make your Baja filter replacement a bit easier.
The PhatDad Inclined Shred Stack. I purchased this item from DDM item number af504.
I would recommend the ADA RC Manifold install at the same time. Part number AV540. See the how-to in this section.
This is a very quick and easy install.
Remove the Baja roll cage.
You will first need to remove your filter system.
This is done by removing the holder by pushing it in and down. I used pliers in the photo.
Next pull the center out. It is only held in place by the o-ring.
Now remove the filter base by removing the two screws or allen bolts that hold it to the manifold. This will also let the carb come loose from the manifold so hold the carb from falling.
Next remove the throttle rod from the carb by pushing the holder down the rod.
After removal inspect your gaskets. This will tell you if the engine has had a gasket leak.
Clean off the carb completely with some carb cleaner and an old tooth brush. You can now inspect your carb for any defects or damage. Take care in inspecting the carb choke. It will be a bit loose but make sure it’s not too loose.
CLICK ON PHOTO FOR VIDEO:
Here is the setup as purchased put in order of installation. Make sure you install lock tight to the bolts before installation.
Reinstall the throttle to the carb.
Refasten the set up on the manifold.
Use some lube to moisten the o-ring and install it until flush in the stack opening.
Now install the clip and click in place.
WAY BETTER!!
Good info, I was looking for this tutorial. So the o-rings go on the front of the stack and u put the screws through the o-rings and snugg down the screws with lock tite. Will blue lock tite be ok. Is this correct.
