bushings are what came with it. do you have this alum knuckle? its hard to explain. the bolt has nothing to bottom out into. Also you have to tighten the top and bottom evenly cause it flexes the alum. make sense?Greggfromohio said:It sounds like the steel bushings aren't long enough
The knuckle is threaded not the carrier.Greggfromohio said:No I do not have them so its kinda hard to make sense of it. To me it looks like there should be bushings in the piece that fastens to the truck(the piece u have your finger on in the first pic) The bushings should be slightly longer than the aluminum tab that they go through and fit loosely so they can turn in there. Then the bolt can bottom out on the bushing and it won't squeeze together and cause binding . Do u know what I'm saying?
Thanks. Going to pick up some longer 4M grubs. Want 6mm long.RCDAD said:That's a great idea!
