how to wire batt up for nem motor
lefnut
is there a video or diagram out there that will show you how to wire up batt in series or parellel to hook up into rampage xbe.
Here are the two configurations. The second photo (series) is the stock set up for the XBE.
Ok rcrdad thanks now my question is if im using 6c batt what way should run them at series or perellel and how do you know what to run them at and what Are the benefit of doing this and why thanks for all of your help new to electric cars.
If I may chime in, if you are running 6 cell packs with the stock setup you must run them in parallel. Running them in series doubles the voltage, running them in parallel doubles the capacity. So as an example, if you run two 3 cell(11.1v) 5000mah packs in series you get 6 cell(22.2v) 5000mah. If you run two 3 cell(11.1v) 5000mah packs in parallel you get 3 cell(11.1v) 10,000mah. The stock ESC can only handle a maximum of 6 cell so if you run the 6 cell packs in series it would make 12 cell.
That's all in the video I posted.
thanks guy that what i need to know. thanks rcdad for evertime i post some thing he chimes in thanks for the help again
All correct info. If you upgrade the the esc and motor they each will come with spec of what they are capable of handling. Like stated above 6s it the most you will want to push through the stock motor and esc. You can increase mah and discharge rate (c rating) Higher is better. :D
