DemonRC1
If I were in your shoes I'd leave the gears at 29/31 and fit a modded rear Dom pipe from an HPI. The rear Dom's are reknowned to give you tons of low end punch. If you replace that Xcan with one your gonna see so much more punch on the bottom and even be much faster on the topend. Your going to have to get somebody with a MIG or TIG to cut it and weld it back together though. The procedure is pretty simple. You only have to cut the pipe in 3 places, turn the tubing 180 degrees, and weld if back together.
