Not sure if anyone is interested or not but I modified the Rampage XB to accept the HPI Baja 5b rear hub assemblies. It was a very easy mod. and only required about 10 minutes per side to complete.
1. Remove Rampage hubs and bearing holders
2. Drill the rear outer "A" arm hinge pin hole to .250" This can be done very easily with a cordless drill and 1/4" bit.
3. Using the Baja 5b lower hinge pin and hub assembly install them as you would with the rampage XB setup.( You will need a shim to take up the slight difference between the width or the rampage arms and the Baja 5b hub for me this was about 1/4-5/16"
4 Remove the upper outside ball link from the Rampage upper arms, replace this with the one from the HPI Baja 5b.
after completing this mod I have had little to no problems with my rear bearings or any slop with the rear hubs. Best of all it will allow you to run Hpi wheels with out modification.
I will get some pictures up if anyone is interested.
Here is a list of the parts you will need to do this mod.
I suggest using the Integy Rear hub Assembly because it comes with bearigns and hubs and hinge pins:
http://www.integy.com/st_prod.html?p_prodid=16865&p_catid=126&ratesortby=New#.U2Ahllf4eac
HPI-86488
HPI-102157
HPI-85465
Greg
HPI-86488
HPI-102157
HPI-85465
Greg
