hpi baja front hubs
clubin not sure if i was clear i ment the 24mm hex hubs i want to run the same tires as the back and a 5t body
yolonda21 said:
You need to put 4 baja rear hubs on these puppies.....♥
dude the front hubs are set up like the baja i just don't know it they will fit length and width
Just install a out drive from the upgrade kit and a rear HPI adapter just like the way the MT is done then you can use HPI tires/rims. I have everything to do it, I just didn't see any point till I got some gears that'll last.
good point on the gears clubin. i was gonna use the outdrive from the upgrade kit but i wanted it to look factory not modded with the cup hangin out there but ill do it anyway
The baja front hubs will fit but you need to do the mod removing the e clip. I have plenty of rear axles but no hubs to go on them so I did a quick mod and installed the HPI front hubs. The hub might work without the mod but it would be a bear to get the e clip on.
