HPI carbon fibre look inner panels
OuttaLuck
Tools and materials required
Jigsaw, flat file, scalpel blade, 1.2mm/1.6mm aluminium sheet, carbon fibre film
Make a template
Remove fuel tank and battery box Note these will have to be removed anyway when you install the panels. now make a template of the inner chassis and transfer to 1.2mm/1.6mm Aluminium sheet.
Now using a jigsaw to cut out the pattern and finish off with a flat file to smooth out any rough edges
Note: test fit panels before applying cf film
Applying carbon fibre film
Cut the carbon fibre film 10mm larger than the panel then apply the the film being careful not to get any air bubbles now turn it over and trim the edges with a sharp scalpel blade or knife.
Fixing the panels
I used rubber silicone applying small dobbs evenly spaced.
The reason i use silicone its easily removed and does not damage any surfaces
Note: Panels are also held firm by the fuel tank and battery box if 1.2mm/1.6mm sheeting are used
Hope you enjoyed this tutorial thanks for looking
Troy
That looks great!! yours looks shiner than mine :( mine was dry cf effect with abit
of shine to it but yours looks mint!!
Great tutorial :D
Great tutorial :D
Thanks Andy you can have em if you want em just gotta paid the postage fee im gunna make some more gotta a m8 thats gunna laser cut a shite load outta thin guage checker plate il do some more CF look aswell
Troy
looks great,i want some of this stuff for bits of my shell and a few places under my shell, i hope i do as good as a job as you have,its just its harder when things have grooves and lips on.
Thx..... The C/F film moulds well using a hair dryer or heat gun you'll be amazed what you can do with it........
Troy
