Hs-5765mh
papaw
Does anyone no what size the screw is for the spline on the HS-5765MH servo, this one is not the size of the original servo size.
You can use the original mounting screws. If you are using the plastic servo posts you will have to drill one new set of holes.
I have the servo mounted, post have been cut using HS-5765MH servo but it didn't have the screw to hold the servo control arm on. The screw that holds the arm onto the spline shaft.
Looks like the spline screw is 2.5mm x 13mm long. I'm not sure in the thread pitch its pretty fine.
