Hub Carrier Replacement help
Mike1525
New Member
Hi guys, nice to meet you all. I've Inherited what I believe to be a king motor baja. I managed to use it for a good few minutes before the rear hub carrier broke. Can anyone recommend the best replacement part? Is it worth getting an alloy version?
I'm aware there are various branded parts that fit this car, so just really want to know the best option available please? Also, any ideas on the engine this one has? It says 360DR on the pull start housing, so I am guessing 36cc?
Thank you. Shame they don't do them in orange though to match the rest of the metal parts. oh well :)
Hostile. Available at DDM.
Taylor RC has them to.
Any ideas on the engine on this? Sure it's a 36cc, all i know for sure it's too loud! haha
I have know idea about motors on the King Motor. Only HPI Bajas.
there are several options. Depends on your location.
For plastic or alloy parts: These include the shim set for change in rear toe angles. My KM baja came equipped with the rear alloy assembly as a stock feature when I bought it.
There are plenty of other options as suggested by others. All are good components.
If you are outside of the USA, there may be other sites that will offer parts without import taxes.
You want to make sure you buy a alloy hub that has toe adjustments. FLM makes a nice ones that uses the hpi toe inserts. Don't be a knucklehead like me and buy the cheap Chinese ones. They suck. GL
