Hub Support replacement
fargophil
I posted the other day about getting a new King Motor truck that arrived with a broken hub support. Thanks to King Motor the replacement part arrived quickly. The bad news is I have no clue how to change out the broken one.
I removed the four bolts that are around the hub but am now stumped. Do I need to remove the screw from the center of the hub? Drive out the pin on the nut looking part of the hub?
Does the rubber boot just slide off or is it attached somehow?
A link to a prior discussion or Youtube video would be a great help/
Well, if it's anything like the 5ive, the grub screw in the centre of the hub comes out, and that's supposed to release the pin on the axle stub ( nut looking thing ) .... But sometimes that pin gets rusty or jammed.... Hammer it out and then it will come apart by sliding it back through the hub and bearings
