Huge impact bent front chasis ,, any better brakes upgrade
gshaba
London
Car was going fast but brakes just slide a lot as it's a heavy xt any upgrades on this discs or etc that I could get there's savox servo on them no need for power
The brakes on the Redcats are really good. They will stop on a dime. Is sound like you need to adjust them, that's all.
You can improve their performance by removing the spring and replacing it with a piece of fuel line.
Here is an example.
Thanks I will give it a go , I just finished straightening up that twist on the chasis looks like new again ,, and it didn't twist from mad it hit concrete straight on I was fearing for more damage ,, another thing is when I am on full accelratation it sounds like it wants to go more , can I gear it up any more or anything not too experienced , thank you for ur help
Yes, you can mount a set of 29,31 gears. That's what the XB uses. It will give more top end.
RCDAD said:
The brakes on the Redcats are really good. They will stop on a dime. Is sound like you need to adjust them, that's all.You can improve their performance by removing the spring and replacing it with a piece of fuel line.
Here is an example.
Thanks RCDAD,
My XT brakes are now better than new!
