Hull trim line question
429CV23
First build of this type for me. I'm at a point where I'm ready to get the electronics set up, but am not sure about the hull trim line. I assume the upper, thinner material will be removed but want to be sure. If that is the trim line, then the control rods will only pass through the deck, which will make setup easier prior to joining the hull and deck.
Thanks!
