hummer engine still wont start
oggie
barrow
hi, i recently posted about my nitrotek hummer not starting, ive tried all the things you lot said to get it going but no luck. the new spark plugs came this morning, fitted them and still it doesn't work, its really annoying me, please help...
is fuel going in ?
Take the plug out and set it on the side of the head still hooked up. Pull over a few times.
Is there spark?
Yes, then flush the fuel out of the bottom end of the motor by tipping the model upside down and pull over about 15 times without the plug on. Dry the plug, reinstall and re try starting. Make sure you are not using the choke.
No, Try another plug - Any plug and set it on the side again and retry. If still no then you need to check the coil and see if it is gapped correctly or damaged.
Its flooding if the plug is wet. You may not have the settings just right to keep running.
