OK yolonda21 where did you get that beauty
I found it at fusion hobbies but big bucks in euros
The Crypton 4WD sets new standards for durability, power train layout and variability. An artful, tried and tested all-wheel-drive concept made to exceptional quality and with excellent handling. Consequently hobby drivers as well as racers can enjoy the new way of driving 4WD.
To compromising nothing in performance, quality and design deliberately none of the already known components was used. On the contrary every single part was CAD designed regarding its use.
The chosen mix of materials shows a perfect combination of power to weight ratio and durability. Therefore the plastic parts are made of many different materials depending on their use. Wherever it was necessary the parts were made from high-grade aluminum. Also many chrome and stainless steel parts are used.
To use a lot of shared parts was emphasized. An example is the suspension arms which are the same on all 4 wheels.
Features
Extreme tough chassis and suspension layout
Drive system: hardened and weight optimized metal gears with sealed gear boxes
Drive shaft power transmission
Alloy differential incl. spiral bevel gear
Double wish bone suspension with maximum setup variability
Large suspension travel
Runs exclusively on ball bearings
Alloy shock absorber incl. progressive springs
Powerful dual disc brake
Adjustable alloy servo saver
Easy access to change the gear ratio
26ccm Zenoah engine (power 2.2KW / 3.0PS)
Factory assembled
Length: 866mm
Width: 470mm height 310mm
Wheelbase: (variable) from 558mm (standard) to 526mm
Weight (without radio control) approx. 11.5kg
Tyre diameter: 176mm, width: 63mm
Camber: front and rear axle adjustable
Toe front- and rear axle adjustable
Fuel tank capacity 650ml
Gear ratio variable in 10 steps from 8.74:1 to 14.27:1
Turning circle: 2.6m
