well amigo thats a loaded question..Lolamstel78 said:Out of curiosity, what aftermarket engines are available that are a direct bolt on?
The CY is an exact bolt in.amstel78 said:Out of curiosity, what aftermarket engines are available that are a direct bolt on?
I've only replaced them for my need for speed. They are a decent engine.In general though, how are the HY engines in terms of overall quality and durability? Will my time with this power plant be short lived? I have experience with 2 strokes as I ride 2 stroke dirt bikes and tend to tune towards a slightly rich side. I plan on maintaining the stock HY as well as I maintain my Kawasaki's...
That can be hard to get rid of with the stock carb.One issue now though is that after the engine warms, it bogs a bit at the low end so i'm going to adjust the low speed screw plus vent the tank.
RCDAD said:That can be hard to get rid of with the stock carb.
The clutch springs can fade when they get hot. I haven't heard of any Redcat owners have this problem with the open clutch. The springs also get week over time, but normally not before the pads are shot.larryo said:Hi what about the clutch spring is getting bad and coming on sooner were the engine is not pulling the rpm for power or torque?
What kind of plating is used in the HY cylinder? Is it Nikasil or are these engines sleeved?xscrick said:pretty much as far as i can tell,, just a cy clone engine,,,and a cy engine is generally a copy of a zenoah.... most parts between the engines are interchangeable,,,,,,, someone correct me if im wrong,,
Nikasil or chrome?RCDAD said:They are plated.
