alfred e numan
- Reaction score
- 0
This HY 30.5 piston has been ringed 2 times- burned about 5 gallons of fuel tru it - always ethanol free- 927@ 25-1. This HY has been tru the mill- Intake leaks- several base gasket blow outs- lean runs - when it had not rained in 7 months to boot. You can see where the piston is starting to rock in the bore a little bit. The clutch side crank seal was letting go- It may not be the most powerful engine- But for $500 bucks for a rtr buggy- shes a solid 10 in my book! - I snagged up some pull off parts last winter- 35 mm bore ready for the 30mm stuffer crank-Nachi bearings- hope the plating holds up as good as the HY has---
