Hydraulic brake problem!! help!
westy77
cambridgeshire
Hi guys,
just in process in fitting hydros front and rear on my mt,my problem is that servo that controls the rear brake and throttle pulls the hydro shaft the wrong way and on acceleration makes the brakes come on.
i persume my servos are wrong or i need to change something any ideas!!
cheers guys
will get photo on as soon as i can,the plate i have has the holes pre drilled for the hydro units so i cant see how i would put it the other way?
your right i need some pics!!
pics of my hydro problems!! help!!
ATTACH]
bit of a mess at the mo guys!!
nothing is fixed securely but this is how it would fix,
as you can see the servo on the right controls throttle meaning that on acceleration it will push plunger in and operate brake,the left servo will control front brake no problems any ideas what i can do?
the radio tray has all the holes pre drilled for the hydro units so it must be designed to take them?
help guys...
Hi westy mate, you need the same linkage setup as you have on the throttle with the slider, spring and colet.
Hope this makes sence, you should have this on both brakes so the master returns back with help from the spring.
If the master has tobe pused in for the brakes to work then both linkages need tobe on the same side of the servo horn to work westy, with the slider/spring and colet setup.
gotcha super!
yeah they need to be pushed in to work so im gonna have to put them on the same side,you think that will work ok??
Trebor has a similar set up on his leopard I think. Im sure there are pics in the leopard section?? Maybe he can post you a pic to show you his set up.
cheers guys
will be getting on with it asap,pics will be up once finished its looking good!!cheers guys
super if you can find them pics would be great mate
tops!!
cheers super...
that explains why the holes are there for the overflow pipes on the radio tray!!
thats a mass of help mate nice one...
