hydro brakes on fg beetle
relocate you reciver to the front middle hole of the roll bar their is another mounting point for your additional servo under the reciever
i have an alloy radio tray but i could do with the relocation bracket...
i have an all alloy welded roll cage with no hole but ill sort that bit out...
ok so i have moved the radio tray and there is room for another servo, if i fit another servo i still have this issue of where i mount the brake cyclinder. its the magura one. with the bright red calipers..
or i do mount the cylinder here, and use my existing throttle and brake servo but then how do i run the linkage...
sorry guys any help you can give is great.. hell ya can you pm with a price for a relocation tray.. ill need it shipping to the UK pls
shipping will cost more than the part:) but I'm willing to ship it to you
heres the cost of shipping
http://ircalc.usps.gov/IntlSummary....0&CertMail=0&RR=0&RM=0&RD=0&date=&surcharge=0
$15 shipped
Bleeding your hydros.....get a syringe from any pharamcy the no needle type...the kind used to dispence childrens medicene in CCs. ....attach a small piece of silicone tubing to the end.
Open the wheel cylinders bleed valve, take off your mastercylinders lid, put 20cc mineral sprits into the syringe attach the silicone tubing to the open wheel valve push the oil from the wheel cylinder to your master. close the bleed valve.
repeat the process for the other side
heres some photos of the brakes installed to give you ideas
so it the old magura withthe master cylinder like in hellya pics ?
yeah.. mines like the 2nd picture...
but on the lefthand side i have brake and throttle control. i think i may put another servo in where the reciever is with a y lead.. then i can mount the hydra on that side of the car.
