I have the my pro and it’s seems that it doesn’t have a good take off. I tuned it right, I’m running a 1:25 ratio. Do u guys know anything I can do t
Romanator
I have the mt pro and it’s seems that it doesn’t have a good take off. I tuned it right, I’m running a 1:25 ratio. Do u guys know anything I can do to gain some more torque. Is there a gear ratio I can get that can make a difference?
That's to be expected with tires that weigh as much as a small sac of potatoes.
stock MT v3 gear ratio -- 25-35-25-25
given the sheer size of it and the wheelsgearchartrampage .webp it's geared for torque, so 25-35-25-25 is the most likely answer for the MT, which would give it a ~1.4 ratio. Either way, does it really matter what the default is? Try it both ways and see which one you like :) Changing it to 25-35-25-25 should give you much better torque, but it will also drop your top speed significantly.
Here is a gear chart u can use to setup different ratios.
what fuel and octane your using? and what oil are you using i found the redline oil at 32:1 best used for years after a rebuild internals looked good!
I'm using 50:1 premix. 95 octane.
Zero issues so far. Broke in at 32:1.
Soon as this gallon of 50:1 is gone, I'm swapping out to 40:1.
