I need a Futaba expert desperatly!
sperera
Australia, Melbourne
Epquipment - 3PKS and 2x R603FS recievers
History - Couple of months i purcahse the 3pks off a forum member, bought myself my first r603fs and installed it into my 2wd fg baja. connected perfect, everything set up fine. few months later bought another r603fs and set it to second model on tx and throttle worked fine but no steering, so switched the channels and i could control steering from trigger, thought to myself must be the rx, so sent the rx back got a refund and purchased another rx (always r603fs) from the same spot i purcahsed the very first one that seemed to connect up no problems. set it to the third model in tx and worked fine, thought sweet now everything set the way i want etc.
tonight ive gone back to use model one (2wd) and ive got no steering!!!!
I have no idea how to fix this, can someone help please??? ???
Try a Mod-Reset on model 2. This can be accessed from the menu screen. It sounds like one of the channels is reassigned to a different function button. This seems like it is a setup error, especially if everything functions properly on channels 3+.
You probably have your steering assigned to an Aux button instead of the steering wheel. Reset the model memory.
