I Need Stiffer Springs
MWhite
Junior Member
Does anyone know if there is a stiffer spring out there for a Rampage MT? If so whats for brand and a Link
Thanks
Let me ask why you think you need stiffer springs, I have been running mine with stock springs for over a year, the only thing I had to do was change the shock oil, I played around with different weights and like everyone on here said 40wt seems to work the best, the only springs that might fit would be HPI but I am not sure
The Baja springs will fit the MT shocks.
For the fronts you use the Baja rear shock springs, just the longer spring as it is a 2pc spring.
For the rears you use the Baja front springs.
As stated heavier shock oil may satisfy your needs. Running around a 40wt and then preloading the spring works great.
RCDAD said:
The Baja springs will fit the MT shocks. For the fronts you use the Baja rear shock springs.
For the rears you use the Baja rear springs, just the longer spring as it is a 2pc spring.
Thanks for the clarification on the hpi springs
Thanks, What I am seeing since I did the electric conversion I get some chassis shag especially when I accelerate or do some big jumps
