i started me km 29 cc baja
It just needs a bit of fine tuning but it doesn't sound that far out to be honest. Take your spark plug out & check the colour. If its black or dark brown its running rich which is the safe side of the settings, a medium brown colour is ideal & light brown or white is lean which means the engine will not be getting enough oil. Have a read of the sticky in the engine section & it will tell you more. If you are out at weekend the lads will help you out if you are not sure.
sounds ok to me kidder, maybe a little rich but now,t to loose any sleep over, if yea taking it to deeside at the weekend sure one of the lads will give it a little tune up for yea,
Go by the color of the plug not the smoke. Smoke will depend on the oil type.
Sounds right to me. I think you are hearing the pop of the pipe and thinking its a back fire.
