Just thought I'd get some feedback on what you guys think my next upgrades should be. Anything seem problematic on the mega beetle? I've done the upgraded clutch bell, the alloy clutch bell holder. Also pipe and air cleaner and two 5755's as well as a 5k hump pack battery.
So I ask guys, what's next?
Have you had this long ? There are loads that you can upgrade to alloy. Are you a basher or a racer, ? are you into jumps, or big jumps
Ive found the front axle mounts are the weak point in my beetle, there plastic, all of my front end is plastic, as i have found over the years once you cange a part to alloy and you take a serious hit its bent, i.e. needs a new one if it cant be straightend out etc. I like the plastic for this reason, The FG plastic is very forgiving and flex's as it needs too.
If your going for the bling look, then its down to your budget
Alloy hubs are a good change if your planning front brakes.
Same with the gears, i always run a plastic spur while the Pinion, lay and diff are steel, i.e. the spur gear is "the week point" - cheap to replace if it strips, that said (touch wood) ive never stripped any :lol:
Alloy or carbon radio tray is always a good upgrade - will help under braking
Street.
